Thermal Runaway A10M
Meller97
Re: Thermal Runaway A10M
Post by Meller97 »
So what was wrong with the software?
Have the same problem.
Hi,you can try to update the firmware.
Meller97
Post by Meller97 »
William wrote: Thu May 28, 2020 10:09 am Hi,you can try to update the firmware.
Thanks William. Just updated it with A10M_G05_V1.1.8_16.hex , but no changes. Still have the same issue.
Also, I've noticed that the bed does not heat in the front position.
Here is the video https://youtu.be/lZa9m4CXh3I . If you are not able to use youtube I can upload it whenever you say.
The printer was purchased less than a month ago, should I go technical support?
UPD. Just measured the bed thermistors, if I am right it is 687 Ohm.
Thank you for the video provided.
According to the video, it may be that the hot bed is not in good contact with the motherboard.
I suggest you check the connection.
Meller97
Post by Meller97 »
William wrote: Thu May 28, 2020 5:55 pm I suggest you check the connection
Twicked all the conections and have tightened all four screws. Everything looks fine. But the problem is still here.
What is next? Should i replace the wires?
Hi,is there some damage?
If you can't see it, you can contact the salesperson on the purchase platform to replace the hotbed.
