Iduino DUE board problem - Outputs and power not working
fkallay.ebay
Post by fkallay.ebay »
Hello
I bought the DUE from following link http://cgi.ebay.com/ws/eBayISAPI.dll?Vi ... =all&tid=0
I have just test it and found that it is not working
When I connect it via USB port - On LED and Led13 are shining. I can send program to board. But it looks that outputs are not working because there is not possible to get Led13 Off. Looks like problem of main processor outputs.
When I connect it with external power it doesn't work completely. And on 5V pin is much higher voltage. Looks that also power part is not working.
I have another DUE board which works properly with the same configuration, so it is not problem of my configuration.
Unfortunately It looks that DUE board I have bought is not usable
Please suggest some solution.
Thank you Fedor
techsupport
Re: Iduino DUE board problem - Outputs and power not working
Post by techsupport »
I replied to your last post, have some new message can feel free to connect us!
Tech Support Team.
Email: forum@geeetech.com
fkallay.ebay
Hello
I have made 3 posts, but they are each for different DUE board with different problem.
So I need help with each one.
I will write information you will ask to each.
This one works this way.
a) When connected via USB only
1. When I connect USB to "Programming port", board is recognized by PC, drivers are found.
Board can be programmed
2.When I connect USB to "Native port", board is recognized, drivers found
So it is possible to program it too.
In both cases when I upload test sketch which switch on/off pin13 outputs are still ON and LED13 is still on.
b) Connected via power connector
1. When I connect USB to "Programming port", board is not recognized by PC
Board could not be programmed
2.When I connect USB to "Native port", board is not recognized
So it is not possible to program it too
In both cases test sketch did not run.
I think there are two probles with this board
1. Power part is not working. On 5V pin is much higher voltage.
2. Outputs of main ARM processor are damaged
Thank you for your help
techsupport
hi, is you use the code we provide?
and Card by working in the rated voltage, is not to need to use additional higher voltage,
it is likely to burn out the card.
fkallay.ebay
Hello
I do not understand what do you mean with "code you provide".
I use code provided e.g. from
examples\01.Basics\Blink
And using card with correct voltage - external power 9V or USB 5V.
On pins 3.3V
Nothing with "higher voltage".
I now for sure, that if there is higher voltage than allowed it will burn board.
This is not my first board, and I have another DUE board working in the same condition correctly.
Some suggestion ?
techsupport
there is not possible to get Led13 Off, Change the code also can not ?
and the board external power it doesn't work completely?
fkallay.ebay
Hello
You are right.
There is not possible to get Led13 Off.
I can change code by any means but there is no change in behavior of the board.
Yes, you re right - when I connected external power, board is not working.
Fedor
will
Post by will »
Ok ,friend, thank you for your help.
We already have a solution ,our service customer will contact you .
Best regards!
