Require full Prusa I3 Aluminium Kit Assembly Instructions
zhangxueyou
Re: Require full Prusa I3 Aluminium Kit Assembly Instruction
Post by zhangxueyou »
You are welcome. Hope you enjoy your printing later.
Cheung Weng
Anabatix
Post by Anabatix »
A couple more questions.
1. I think I must cut the white plug off the 12vDC power, strip and screw into board directly? As the photo you show can't be the same board design as in the kit for Ramps 1.4... correct?
2. The 2x Z Axis stepper motors, the white plugs to connect to the Ramps board will never fit. Have you tried it on your Kit. What do you suggest for an easy fix?
3. Could you post some good photos of a completed Prusa Alu Kitset so I can check the layout is as intended. Your manual does not show board or extruder mounting etc. And cable layout around motors.
4. Could you post a Ramps 1.4 finished wiring photo as it is worth 1000 words. And will explain better the power, fan and heatbed wiring using this kitset.
Thanks,
Lee
zhangxueyou
I will give you the pictures of all the wiring of all the parts. Please, you must understand my pictures because I spent a lot time assembling. If you have any problem, please reply me T_T
Ramp1.4+Mega2560
Jumper caps
zhangxueyou
Cooling fan for mainboard
Cooling fan.png (397.42 KiB) Viewed 36981 times
Cooling fan2.png (524.28 KiB) Viewed 36981 times
Extruder motor
Extruder motor wiring.png (601.39 KiB) Viewed 36981 times
zhangxueyou
Themistor on hotbed
Thermistor on hotbed2.png (183.19 KiB) Viewed 36981 times
Thermistor on hotbed.png (806.05 KiB) Viewed 36981 times
zhangxueyou
Hotbed
hotbed wiring.png (345.6 KiB) Viewed 36981 times
Wirng of Endstop
wiring of endstop.png (557.72 KiB) Viewed 36981 times
zhangxueyou
Power supply
Power supply wiring2.png (195.88 KiB) Viewed 36981 times
Power supply wiring.png (635.95 KiB) Viewed 36981 times
zhangxueyou
LCD
LCD wiring.png (569.16 KiB) Viewed 36981 times
zhangxueyou
Wiring of extruder
Wiring of extruder.png (534.37 KiB) Viewed 36981 times
Wiring of thermistor for extruder
Wiring of themistor for Exturder.png (419.83 KiB) Viewed 36981 times
zhangxueyou
Switch
