EndStops problem
george6robles
Re: EndStops problem
I have good prints. Need help with end stops
george6robles
what about the end stops not working?
What about the firmware for the three boards I have?
ramps 1.4 and iduino
sanguinololu 1.4
gt2560
still waiting for the reply as you have only sent me settings that I have setup almost the exact same before you sent it to me.
I need to know how to fix my endstops.
sanguinololu 1.4
gt2560
zhangxueyou
Please leave your email address, so that I can send you the firmwares.
As for the endstop issue, please confirm the conncetion of endstops are correct, you'd better leave a picture of mainboard, let me check. Then update the firmware.
george6robles
george6robles@gmail.com
Is my email.
End stops are correctly connected.
I will send pictures via email.
Is my email.
george6robles
Okay. I stand corrected. I did have x and y mixed up. I had bad firmware and a bad driver at first and I had to try all kinds of things that I completely forgot to switch them back. So my fault for trying to take on all things at once. Pays to double check everything again!
moussawi22
hello please i need help my y- axis is not moving at all. it has a current because it gets stiff but it doesnt move, all the other axis are working fine!
zhangxueyou
Please loosen the y belt slightly, maybe it's too tight to let the belt move.moussawi22 wrote:hello please i need help my y- axis is not moving at all. it has a current because it gets stiff but it doesnt move, all the other axis are working fine!
it seems a similar probem on my i3 pro C dual extruder 3D printer with GT2560 board and 1.75mm filament. The firmware has the end stops active for x,y and z.
Could you send me the correct firmware please?
zhangxueyou
First of all, please confirm the endstops are connected to X-MIN,Y-MIN,Z-MIN.mallensp wrote:Hi,
The email we sent you was rejected, do you have another email address?
hi,
yes the endstops are connected correctly. I checked wire by wire of the complete printer.
Heatbed incl. thermistor and the extruders are running perfectly.
For testing, i used a bridge for the y-max endstop and this unblocked the y-stage!
Further testing with x-max, y-max and z-max bridged resolved my problem temporary,
until i receive the firmware to correct it permanently.
Then i started the calibration process and the amount of steps/mm for x and y needs to changed
also.
According to the tutorials this has to be fixed in the configuration.h file also.
Now, minutes later without any interaction (the printer was only switch on) the printer stoped
everithing, including the fans! only the power indicator is still on.
And the problem remains after restart (including remove the power cable) .
I have no idea of what kind of problem this is!!!
also.
