Heat Bed and LCD Issues
Xadamx1
Re: Heat Bed and LCD Issues
Post by Xadamx1 »
Any ideas on what to try next?
zhangxueyou
Post by zhangxueyou »
About the endstops, please recognize every axis and connect the endstops correctly.
As shown in the picture, from left to right should be x, y ,z .
Xadamx1
Post by Xadamx1 »
The end stops are connected correctly, I will take a picture when I am home from work. That I'd the first thing I tried. I even switched the x endstop with the y end stop and then y stopped working. I believe it should be the switch.
Xadamx1
Post by Xadamx1 »
http://imgur.com/a/8L3Kb Here's the end stop.
zhangxueyou
I think somewhere of the endstop wire is broken, the endstop can not be easily bad.
Xadamx1
Post by Xadamx1 »
This morning I switched the wires on the x end stop with the ones on the y end stop. The y is now the black.wires while x is blue. The y end stop still worked with the new wires, however the x end stop did not. http://imgur.com/a/WDrsf
zhangxueyou
Please tell me your purchase link and order number, if you bought the printer from us, let me tell the customer service your problem. That will be faster solve your problem.
Xadamx1
Post by Xadamx1 »
I bought the printer from your company on Amazon. Here is my order number: 102-7795247-4495433. The email address associated with my amazon account is adamphlipot@knights.ucf.edu.
tuncangin
Post by tuncangin »
I had this issue too but i found the problem where it is. If you have the acrylic part of geeetech lcd2004 controller, do not screw its 4 screws much more. When you just pinch them much the boards of lcd panel are touching each other.
Xadamx1
Post by Xadamx1 »
Are you talking about the LCD mount st the top of the printer? Of so when I get home on Wednesday night I'll try that and save myself the freight to send it back. Thanks!
