I have double checked all my cables, they are all plugged in the same(they are keyed so it makes it hard not to). When I issue the M119 command I get the following(which seems correct)
14:53:20.846 : Reporting endstop status
14:53:20.846 : x_max: open
14:53:20.846 : y_max: open
14:53:20.846 : z_min: open
14:53:20.846 : z_max: open
But when I home, it always takes the z-axis up, and the x and y axis down, to the point it locks up the cradle if I don't emergency stop it.
Mini G2S z-axis goes up when homing, the rest go down.
Re: Mini G2S z-axis goes up when homing, the rest go down.
you motor goes in the wrog direction, you should change them here in the firmware:
change the corresponding settings here and ready to hit the emergency stop button if necessary!
#define INVERT_X_DIR true // for Mendel set to false, for Orca setto true
#define INVERT_Y_DIR false // for Mendel set to true, for Orca set to false
#define INVERT_Z_DIR true // for Mendel set to false, for Orca setto true
and you can refer to the link here to check the other things:
http://www.geeetech.com/forum/viewtopic ... 13&t=17042
