X & Y positions inaccurate, Z position is accurate ???
divtec
Post by divtec »
X and Y positions are consistently NOT accurate. However, the Z Axis is accurate.
My workaround was to set the X, Y, Z steps/mm from 80 to 68.8 steps/mm then scale the Z axis to compensate.
This work-around is barely usable and must be done for each file loaded.
Any suggestions?
Mark
Re: X & Y positions inaccurate, Z position is accurate ???
Post by Mark »
what do you mean by not accurate?
divtec
Post by divtec »
Factory settings for X, Y, Z are 80 steps/mm. Example... If I issue a 50mm move on X axis the actual is 57mm. Note that the z axis moves correctly 50 mm if issued the same command.
Mark
Post by Mark »
I see, but let's say if it should be 68.8, so what I don't understand is why did you scale the Z zxis? I think it doesn't make sense since 68.8 is the correct steps then you needn't to scale Z anymore.
divtec
Post by divtec »
Because this is DELTA printer and all towers (X,Y,Z) must be set to the same Steps/mm.
So... as a work-around if I make X & Y accurate I then must compensate the Z movement by scaling.
By the way... I uploaded new Firmware and no longer have the problem. All axes movement are accurate now.
divtec
Post by divtec »
Oh... almost forgot... another problem.
When trying to user Extruder 2... all axes (x, y, z) will move toward home (and ignore limit switches) when a extrude command is given.
There is a thread about this problem... I posted... but, no reply. You claimed months ago that you thought you have it fixed back in July... but, problem still exists after uploading the latest Firmware.
PLEASE FIX THIS! I bought a G2s because I wanted to print two colors. Arrgh!
Thanks in advance for you rapid solution.
Mark
Post by Mark »
Did you choose the correct firmware for your printer? you can check this link here:
http://www.geeetech.com/forum/viewtopic ... 13&t=17064
