X axis homing failure
klmjr22
Post by klmjr22 »
I just finished assembling and started testing my Prusa I3 all aluminum printer what I have tested so far works fine with one exception. the X axis will not home properly. Y and Z work exactly as expected. What X does is when I hit Auto Home X will move to the right as it should, then it stops and immediately goes to the Y axis which moves forward then back to the home switch. After Y is finished the Z axis moves up the homes and stops. If I go to manual jog on X axis i can jog to the right as it should. When i spin the knob back to zero, the X axis move back exactly to its starting location. I also reloaded the firmware following the directions on this site. I did try once reversing the X axis during auto home it moved to the left the same amount it had moved to the right before then immediately jumps to Y home which works then Z which also works. I even disconnected the X home switch it still works the same. It is literally driving me nuts. All I can assume is a hardware defect on the Sanguinololu board. The software I used was Plusa I3 A Sanguinololu.
Mark
Re: X axis homing failure
Post by Mark »
sorry although you wirte so much, but I am still confused...did you mean yor X axis direction is reversed when homing?
klmjr22
Post by klmjr22 »
No it goes in a posative dirction. It never reverses towards the home switch it appears it sets the new location to home. If repeated the head will keep moving to the right every time you hit auto home. It seems to move about 2 cm each time. And that location is set as X axis zero.
Mark
Post by Mark »
seems your X axis endstop wiring has a bad conact, or the endstop driection in the firmware is reversed, you can change the settings here and upload the firmware again:
// The pullups are needed if you directly connect a mechanical endswitch between the signal and ground pins.
you might need to try a second time, cause you don't konw it is true or false in your original firmware.
klmjr22
Post by klmjr22 »
The problem is solved. It turns out one of the connections on the X axis switch was not stripped before the terminal was crimped on so no connection no X axis home. A little solder and the printer is working and printing. Thank you everyone for your help.
Keith
fire012
Post by fire012 »
Greetings,
The X axis from "Control Board" does not give a constant signal to the stepper motor! the motor " Jettiring" I try to connect other motors to the same output, and all the motors did the same thing! So, the issue is not from the motors. it's from the BOARD!
What should i do?
I purchase it from Bangood.com:
http://www.banggood.com/Geeetech-Alumin ... 98030.html
Your product link:
http://www.geeetech.com/geeetech-alumin ... p-944.html
Admin
Post by Admin »
please check this for trouble shooting
