Hi to all
I've bought a Geeetech A10 printer right now.
Some questions as new user:
1) during the next months I would like to upgrade to the A10M version. Is this the only kit I need ? Does it come with the new two extruder and the dual-in one-out hot-end ?
2) I've seen that LCD ribbon is a weak part of this printer, because is not protected at all. Any fix to this ? Maybe something to print or a longer ribbon cable to route differently
3) i've also ordered the 3DTouch sensor, should I add something else to use it or the A10 is coming with anything needed except the sensor itself?
4) any suggested upgrade or suggested print ?
5) in the Ender 3 there are some "chain" to print to better protect the cables. Anything similiar for this printer ?
Thank you
New user - some questions
Re: New user - some questions
Hey Gandalf.
Did you make the upgrade with this Toolkit to A10M?
Greetings Copyyy
Greetings Copyyy
Hello.
Extending a flat FFC cable to a display can be a bad idea.
This is because of the sensitive digital signals and interference.
