Hello.
I'm just buy the printer geeetech A10m and starting the configuration for the first time I have a trouble.
the wire for Z axis end stop doesn't work (I think) cause the red light still on. I think that this is the problem that produce the fail in my printer.
After the 4 corner configuration (that the printer do it correctly) the printer start to print the model leaving the filament 10 mm aprox. over the bed, and if I stop the printing and I send the extruder to auto home, the Printer restart 10 mm over the previous home position.
... and i must restart the configuration.
Could you take me a hand ?
Thanks.
A10 M
Re: A10 M
I have exactly this problem and I don't know what I have to do. Is mandatory to remove the old z endstop ? In case yes , How I should do it ?vert wrote: Sat Feb 23, 2019 3:14 am Only time I have seen the z endstop light up is with a 3dtouch/ bltouch installed and you didn't remove the old z endstop.
