Page 2 of 7
Re: acrylic I3 motor issues
Posted: Fri Feb 13, 2015 8:14 pm
by buzmal
how do i edit the firmware? i am quite new to all this, can i edit the firmware on the board or do i have to download new firmware and then reinstall it??
Posted: Sat Feb 14, 2015 9:21 am
by harry_chen
You should download a firmware. Edit and compile on computer, then onnect the board and computer, and burn it into the board.
Posted: Sat Feb 14, 2015 2:37 pm
by buzmal
what firmware is currently in use do i just download any copy of marlin or is there a geetech spacific file i should use
Posted: Sat Feb 14, 2015 3:17 pm
by harry_chen
Please leave your email address,
I'll send you one which we are using.
Posted: Sat Feb 14, 2015 3:50 pm
by buzmal
hi please forward it to
gmbuzmal@gmail.com
Posted: Sun Feb 15, 2015 8:31 am
by buzmal
I have received the file but there doesn't appear to be a file i can open with ardunio to edit, it tells me i can only open .ino or .pde files and everything in the zip is .cpp or .h, some guidance is needed....
Posted: Mon Feb 16, 2015 8:53 am
by buzmal
hi thanks for the reply via email, the only thing i need to work out now is the z axis endstop positioning, but i will post again if any further hel is needed
Posted: Mon Feb 16, 2015 9:16 am
by harry_chen
Glad to hear that, good luck!
Posted: Mon Feb 16, 2015 8:20 pm
by buzmal
so i have got all the axis working and if i run the system the printer moves as it should, however the extruder isn't functioning correctly, I am using 3mm filament, and the video
https://www.youtube.com/watch?v=EpHmXHF ... e=youtu.be will illustrate what is happening, if i loosen the top screw the motor will spin freely what can i do to fix this issues.
Posted: Tue Feb 17, 2015 9:02 am
by harry_chen
What is the filament you use and the nozzle's temprature?
Is the problem similiar to yours?
https://docs.google.com/file/d/0B5w3QL5 ... cslist_api
And the solution:
http://www.geeetech.com/forum/viewtopic ... 995#p21205
