Page 2 of 2
Re: Acrylic Prusa I3 pro B motor move only one direction
Posted: Tue Dec 06, 2016 2:36 pm
Sound likes the connection of endstops...
Can you "Move Axis" on LCD to every motor?
Posted: Tue Dec 06, 2016 5:47 pm
by tiffy
Yes i can. The same thing happens.
Posted: Tue Dec 06, 2016 10:33 pm
by tiffy
Yeah. You were right, problem was associated with endstop switches. Solved! Thanks a lot.
Posted: Wed Dec 07, 2016 5:32 pm
So how did you discover it finally?
Posted: Wed Dec 07, 2016 8:23 pm
by tiffy
Good. Now i am printing monkey) i need to get more experience about printing, filaments, printing speed and nozzle temperature
Posted: Wed Dec 07, 2016 8:25 pm
by tiffy
I discovered it according to your post. Just limitswitches were not connected correctly as you said.
Posted: Thu Dec 08, 2016 10:07 am
Anyway,congratulations
@tiffy
Posted: Fri Jan 27, 2017 11:25 am
by rsreed
I just found this thread when I was searching for a solution to a similar problem. In my case my X was working but Y would only go + and Z would only go +. The limit switches were indeed the solution but I installed them as they looked like they should be in the assembly instructions .pdf.
After reading this thread, I had my son pull up a generic GT2560 wiring diagram and so I plugged in to each axis minimum limit socket. Now all works just like it should.
It turns out that the assembly pictures just weren't clear to me as far as how the switches should be plugged into the board. I've attached a .jpg for reference. Hope this helps someone else.
Randal
