Page 2 of 3
Re: Heatbed MK2a does not work
Posted: Mon May 04, 2015 11:38 am
by uscachi@gmail.com
GEEEtech-PI3A
2. The default is 0.3mm nozzle for 1.75mm filament.
3. The default board is Sanguinololu
4. The default stepper driver is A4988
6.The default Display is LCD2004.
http://www.ebay.com/itm/Free-Shipping-N ... 1707158231
Posted: Mon May 11, 2015 12:08 am
can you send the correct firmware? My printer type was described in my last post, thanks.
GEEEtech-PI3A
Posted: Mon May 11, 2015 12:43 am
I tried to update the firmware following the steps in the link you sent me:
http://geeetech.com/forum/viewtopic.php?f=20&t=16253
but at the verification step arduino shown a error:
core.a(main.cpp.o): In function `main':
C:\Users\Javier\Downloads\3D printer\Firmware\arduino-1.0.1\hardware\sanguino\cores\arduino/main.cpp:11: undefined reference to `setup'
C:\Users\Javier\Downloads\3D printer\Firmware\arduino-1.0.1\hardware\sanguino\cores\arduino/main.cpp:14: undefined reference to `loop'
waiting for your help...Thanks
Posted: Mon May 11, 2015 9:30 am
by zhangxueyou
When you open "arduino.exe", is the windows empty before you drag the files into arduino? If not ,delete the contents first.
You need to drag the 59 files together.
Posted: Tue May 12, 2015 12:55 pm
I updated successfully the firmware of 3D printer following all the steps in the link:
http://www.geeetech.com/forum/viewtopic ... 20&t=16253 and using the firmware sent to my email by
Cheung.Weng@geeetech.cn
When I turn on the printer it was ok, all the motors was working fine, then i turn on the heatbed, it start to heat, but the fan stop working as well as the motors. then i realized that heatbed was heating continuously more than programed temperature. Then I turn off and turn on everything, the heatbed start to heat by itself then the transistor burned producing fire, now the computer does not recognize the printer. I paid $490 for the printer, I am sincerely disappointed. Hope we can solve this problem.
Posted: Tue May 12, 2015 2:17 pm
by zhangxueyou
How did you mount the mainboard on acrylic plate?
Posted: Wed May 13, 2015 12:23 pm
As indicated in the link sent by the seller:
http://www.geeetech.com/wiki/index.php/ ... n%288mm%29
I answered your question?
Posted: Wed May 13, 2015 2:10 pm
by zhangxueyou
No, I need some photos of your printer with mainboard.
Posted: Wed May 13, 2015 8:25 pm
Your questions should be clear in order to optimize the time, sending you the photos. Hope the photos will solve the problem
Posted: Thu May 14, 2015 9:34 am
by zhangxueyou
Please check if somewhere of the hotbed wire is touched. Maybe it is short circuit that caused over high current, so the board is burnt.
