Page 2 of 3
Re: axis problem
Posted: Tue May 12, 2015 2:36 am
by kaiser1
when i use the home option on the lcd screen the y axis wont stop and z dosnt move
Re: axis problem
Posted: Tue May 12, 2015 9:12 am
by zhangxueyou
How about re-uploading the firmware?
Re: axis problem
Posted: Fri Jun 05, 2015 10:10 pm
by kaiser1
How can i do this?
Re: axis problem
Posted: Sat Jun 06, 2015 10:02 am
by zhangxueyou
You can upload the firmware following this page:
I've sent you the firmware last month, please check your email.
Re: axis problem
Posted: Fri Jun 12, 2015 1:04 am
by kaiser1
thank you now it works. but when i try to print nothing come out, i put the filament in the hot end and take the extrusor to 200 °C.
Re: axis problem
Posted: Fri Jun 12, 2015 9:06 am
by zhangxueyou
What filament are you using? If it's ABS, the temperature should be 240.
If you are using PLA, please check if the extruder motor can move without filament first. If it moves, I think there are potential reasons:
1. The distance between nozzle and hot bed is too small to let the filament come out.
2. The extruding tension is not proper. Please rotate the screw across spring in extruder until it can feed the filament.
3. The power for extruder motor is not high enough, please rotate the screw on extruder motor driver, to let the voltage between the screw and GND is more than 1V.
4. The slicer setting is not so good, you can refer to this page to improve it:
http://www.geeetech.com/forum/viewtopic ... 24&t=16366
If it does not moves, please check if the extruder motor or motor driver is fine:
1. Turn off the printer, swap extruder motor driver with x or y motor driver, turn on thr printer raise the extruder temperature to 200 degree, check if it moves.
2. Connect extruder motor to x motor slot, check if the extruder motor moves withtou filament when homing.
Re: axis problem
Posted: Fri Jun 12, 2015 4:06 pm
by kaiser1
I'm usino abs i tryed 240 but nothing.
Re: axis problem
Posted: Sat Jun 13, 2015 9:01 am
by zhangxueyou
Please speak more details.
Re: axis problem
Posted: Sat Jun 13, 2015 6:37 pm
by kaiser1
I'm using the ABS filamenti i tryed with 240 degree but nothing happend. I Aldo tryed to swap x motore driver with the extruder driver and i can move it with repitier. But when i try to print the extruder motor in the extruder driver didn't move.
Re: axis problem
Posted: Mon Jun 15, 2015 10:19 am
by zhangxueyou
I am a little confused by you. The driver I call is A4988 or DRV8825, but the driver you call seems to be motor slot.
