Firmware request GT2560
chai707
Re: Firmware request GT2560
Post by chai707 »
me too Pls. firmware for Prusi I3 X motherboard GT2560.
chai707 » 07 Aug 2015 03:49
The firmware has been sent to your mailbox,please check it.
jamest
Post by jamest »
keep getting time.h error????????
TheJoeShmoShow
Post by TheJoeShmoShow »
If I could get a copy of the firmware for the I3 X GT2560 (Single Extruder) as well, that would be much appreciated.
TommyW
Post by TommyW »
Hi Mark,
I'd need a firmware as for I3 PRO X - I downloaded the source code package you've linked earlier to this thread, but it does not get compiled without errors using Arduino 1.0.1 (+ 'Arduino Mega 2560 or Mega ADK' board selected) :-(
I tried the compiling process with another source code (GT_I3_pro_B) and it compiles without errors.
I3 PRO X get compiled also if I copy-paste LiquidCrystal.h and LiquidCrystal.cpp from Arduino's library folder to Marlin source code folder - but I assume this is not right solution?
Can you please verify you have linked right version?
Here attached compiling errors:
Code: Select all
In file included from ultralcd.cpp:41:
ultralcd_implementation_hitachi_HD44780.h:208: error: 'LiquidCrystal' does not name a type
/ultralcd_implementation_hitachi_HD44780.h: In function 'void lcd_set_custom_characters()':
ultralcd_implementation_hitachi_HD44780.h:365: error: 'lcd' was not declared in this scope
/ultralcd_implementation_hitachi_HD44780.h: In function 'void lcd_implementation_init()':
ultralcd_implementation_hitachi_HD44780.h:403: error: 'lcd' was not declared in this scope
/ultralcd_implementation_hitachi_HD44780.h: In function 'void lcd_implementation_clear()':
ultralcd_implementation_hitachi_HD44780.h:416: error: 'lcd' was not declared in this scope
/ultralcd_implementation_hitachi_HD44780.h: In function 'void lcd_printPGM(const char*)':
ultralcd_implementation_hitachi_HD44780.h:424: error: 'lcd' was not declared in this scope
/ultralcd_implementation_hitachi_HD44780.h: In function 'void lcd_implementation_status_screen()':
ultralcd_implementation_hitachi_HD44780.h:484: error: 'lcd' was not declared in this scope
/ultralcd_implementation_hitachi_HD44780.h: In function 'void lcd_implementation_drawmenu_generic(uint8_t, const char*, char, char)':
ultralcd_implementation_hitachi_HD44780.h:632: error: 'lcd' was not declared in this scope
/ultralcd_implementation_hitachi_HD44780.h: In function 'void lcd_implementation_drawmenu_setting_edit_generic(uint8_t, const char*, char, char*)':
ultralcd_implementation_hitachi_HD44780.h:654: error: 'lcd' was not declared in this scope
/ultralcd_implementation_hitachi_HD44780.h: In function 'void lcd_implementation_drawmenu_setting_edit_generic_P(uint8_t, const char*, char, const char*)':
ultralcd_implementation_hitachi_HD44780.h:676: error: 'lcd' was not declared in this scope
/ultralcd_implementation_hitachi_HD44780.h: In function 'void lcd_implementation_drawedit(const char*, char*)':
ultralcd_implementation_hitachi_HD44780.h:731: error: 'lcd' was not declared in this scope
/ultralcd_implementation_hitachi_HD44780.h: In function 'void lcd_implementation_drawmenu_sdfile_selected(uint8_t, const char*, const char*, char*)':
ultralcd_implementation_hitachi_HD44780.h:745: error: 'lcd' was not declared in this scope
/ultralcd_implementation_hitachi_HD44780.h: In function 'void lcd_implementation_drawmenu_sdfile(uint8_t, const char*, const char*, char*)':
ultralcd_implementation_hitachi_HD44780.h:765: error: 'lcd' was not declared in this scope
/ultralcd_implementation_hitachi_HD44780.h: In function 'void lcd_implementation_drawmenu_sddirectory_selected(uint8_t, const char*, const char*, char*)':
ultralcd_implementation_hitachi_HD44780.h:785: error: 'lcd' was not declared in this scope
/ultralcd_implementation_hitachi_HD44780.h: In function 'void lcd_implementation_drawmenu_sddirectory(uint8_t, const char*, const char*, char*)':
ultralcd_implementation_hitachi_HD44780.h:806: error: 'lcd' was not declared in this scope
Your problem is something wrong with the LCD define. Do you delete the “//” from “//#define REPRAP_DISCOUNT_SMART_CONTROLLER”?
If you did that,and it's not working, then the firmware is wrong. Cause my firmware can be compiled without error, I'll attach it here.
I3_pro_X.zip
(280.86 KiB) Downloaded 738 times
TommyW
Post by TommyW »
Thank you - now it compiles without errors. In previous version I downloaded the Marlin.ino file was empty instead having these crucial lines:
Code: Select all
#include "Configuration.h"
#include "pins.h"
#ifdef ULTRA_LCD
  #if defined(LCD_I2C_TYPE_PCF8575)
    #include <Wire.h>
    #include <LiquidCrystal_I2C.h>
  #elif defined(LCD_I2C_TYPE_MCP23017) || defined(LCD_I2C_TYPE_MCP23008)
    #include <Wire.h>
    #include <LiquidTWI2.h>
  #elif defined(DOGLCD)
    #include <U8glib.h> // library for graphics LCD by Oli Kraus (https://code.google.com/p/u8glib/)
  #else
    #include <LiquidCrystal.h> // library for character LCD
  #endif
#endif
#if defined(DIGIPOTSS_PIN) && DIGIPOTSS_PIN > -1
#include <SPI.h>
#endif
#if defined(DIGIPOT_I2C)
  #include <Wire.h>
#endif
Cmartin
Post by Cmartin »
Hello Mark,
Thank you for posting the correct version of Marlin for the single board GT2560!
I have been having all the extruder drive issues everyone seems to be experiencing.
After using your posted version of Marlin I successfully compiled and uploaded it but I still
cant get the extruder motor to drive media.
Any suggestions?
Can you manually control the extruder motor turning? If it works, then you can heat up the hotend and try to feed it with your hand. If the filament still can't come out, it must be jammed, you'll have to clean it.
Cmartin
Post by Cmartin »
After using your posted version of Marlin (Marlin_GT2560-PI3_Pro_C.zip) I successfully
compiled and uploaded it but I still can't get the extruder motor to drive media.
When trying to drive the Extruder through Repetier there is no motion, When trying
to get the extruder motor to drive using the .1 feed on the LCD control panel I get
NO motion.
The extruder tip temperature is 230, bed is at 95.
As to the filament being fed properly....yes its it in the correct feed location when I push
down on the friction bar and push on the filament it comes out the other side just fine- no jam
