Delta Rostock mini G2s Extruder drives Axial motors
Re: Delta Rostock mini G2s Extruder drives Axial motors
Hi Flamtap,
What a shame I already packed up my printer for return to Getech because setting it up totally as a single nozzle printer is something I had not considered trying before. Anyway, if my Ramps 1.4 board arrived before I would have simply swapped out the controller and replaced it with a standard Ramps 1.4 board bypassing all the inherent issues related to using an old version of firmware as the software base for this printer.
Additionally I suspect that there may be issues related to the operating system version and IU suspect that the Arduino IDE is not behaving properly under Windows 10, but I have no way of verifying other versions and configurations. Additionally I wish I knew how to handle arduino binary images so we could upload a binary image to the board to bypass the possibility of compiling/linking errors on the compilation platform.
I will hang around this forum to see how this equipment progresses even though I am moving to another Delta platform.
Cheers, Rick
Cheers, Rick
Bump.
Same issue here. Single head printing works well; extruding with head 2 causes z axis to raise. Speed seems to be in relation to extrusion speed requested.
This is a bug of the firmware, testing it now.
brent_jackson
It has been 2 weeks now... any update to fix this problem?Re: Delta Rostock mini G2s Extruder drives Axial motors
Postby Mark » Tue Sep 08, 2015 8:34 pm
We are testing the latest firmware now, it won't take long to fix the problem, plz wait with patience, tks!
The firmware looks good for now, I'll send the firmware and the settings to you if you want to have a try.
Yes, please post what you have and what we need to do here. That would be very helpful. Thanks, RickMark wrote:The firmware looks good for now, I'll send the firmware and the settings to you if you want to have a try.
Yes, please post it here.
Also, is this a custom part of the Marlin firmware or something? Why is the problem caused/fixed by Geeetech changes?
flamtap
flamtap
Google+ community for Geetech Delta printers
Hello Mark,
If you would, please send it to me as well - I'd love to give it a try.
Thanks,
Jeff
Thanks,
Jeff
How is this firmware update working for everyone?
Could we post it to this forum, or could someone PM me a copy?
Thanks!
Thanks!
Hi guys, download the firmware here:
http://www.geeetech.com/forum/viewtopic ... 10&t=17046
