I was trying to record everything today to show what was wrong.
And when I begun the printer started printing in the correct way. On the printing bed.
Adjusted the printing bed for correct leveling. Started the job again.
And my filament doesn't come out the nozzle. Temperatures are correct for extruder and bed. The motor of the extruder doesn't move or make any sound.
I checked the wiring.
Then did a step back and tried to manually extrude but then my Y axis moved back very slowly to home stop. If I retract it goes to the end evenly slow.
My guess something in the code mixed up?
Do I make a new topic for this??
X Y Homing position not working
Re: X Y Homing position not working
did you plug the motors in the correct position?seems you have wrongly connected the Y and E motor?
No my Y motor act as they should, but my extruder also makes my Y axis move but lot slower, it acts like the extruder motor works but then on my Y axis.
Do you have a picture of your wirings? if your connections are correct, then have you used the correct firmware?
