How to fix-E180>The screen displayed not correct or black screen
michaelconti
Re: How to fix-E180>The screen displayed not correct or black screen
for 2 days the priner works fine but after i upload 2 file the problem return...randomly the printer turn off...and restart
Could you upload the gcode files of yours?michaelconti wrote: Sat Mar 31, 2018 5:48 am for 2 days the priner works fine but after i upload 2 file the problem return...randomly the printer turn off...and restart
We need to check it and get more details from it.
Running :
MB FW 1.23.25
Screen FW 1.23.25
Since i made update with Update Toolkits, touch screen doesn't answer any more, rolling back to 1.0.2 fw doesn't solve the probleme, trying this zip file (https://www.geeetech.com/forum/viewtopi ... 64&t=60677), doesn't solve it too.
Is there a way to made a hard reset ? and retrive the full stock config ?
MB FW 1.23.25
Screen FW 1.23.25
[quote=Deennoo post_id=83690 time=1523119363 user_id=63098]
Running :
MB FW 1.23.25
Screen FW 1.23.25
[/quote]
Solve following this video :
https://www.youtube.com/watch?v=NDHsKXM ... e=youtu.be
thx geeetech for your none help
Running :
MB FW 1.23.25
Screen FW 1.23.25
[/quote]
Man, i don't even know how to thank you. My printer was broken, I was super angry and tried lots of different stuff, and finally, this fixed my printer! Thanks so much!
Evening All,
And what about does user´s that don´t have hardware experience?? My printer came out of the box yesterday and only printed one model. The screen is stuck in the main menu. Who can help me? does the waranty solve this??
Thank you NG
Thank you NG
Hi,can you describe your situation in detail? So that we can better solve.
WOW this actual fixed my problem 100%
i was printing from laptop threw usb cord got 3 prints then printer started acting bad. staying in same spot for long time clicking so i stopped print started again same thing. odd. so i put file on card. put card in printer and screen was locked up. restarted printer screen was light up but odd lines no logo . no icons. i touch screen numbers came up sideways WTH i try and print from computer get crazy flat print that tore my tape. i take apart try video on facebook ribbin off on. nothing. i try format card from screen download zip install in root. bamb working 100%.
THANK YOU
love the printer
THANK YOU
Black screen - I need help.
At first from display disappeared graphics, the backlight and buzzer worked when touched.
The file system on the card was damaged.
According to the advice from the forum, I copied graphic files and, unfortunately, firmware to the card. After that, the display never lights up again and I can't hear the buzzer.
I tried all firmware - of course, uploading the coresponding flash to minebord. Each time, of course, the config.txt and E180.bin files die from the card, I try use meny card in FAT and FAT32.
I tried to use firmwaretool V2.0 but it creates a cofig.txt file on the card that the LCD bootloader does not understand and LCD does not delete files.
I ordered a new display, but after connecting and load SD with graphics some functions did not work - e.g. did not show temperature.
I decided to upload the new firmware (I had E180_M04_V1_41.bin in the matherboard) - BOOM again the same as with the first display
The printer from the EasyPrint application works correctly and I like it, but the display's lack drives me crazy
Is there something I missed?
Should the LCD powered on the 5V table turn on / work?
Can I upload a working flasch via ST-Link (without damaging the bootloader)?
If I buy another LCD, can I use ST-Linkto download flash from it and upload it to the "damaged" ones?
Any other ideas?
Regards
Any other ideas?
Regards
Hi, from your description, the motherboard is normal,smiehoo wrote: Mon Mar 30, 2020 1:27 am Black screen - I need help.
I decided to upload the new firmware (I had E180_M04_V1_41.bin in the matherboard) - BOOM again the same as with the first display.
The printer from the EasyPrint application works correctly and I like it, but the display's lack drives me crazy.
Any other ideas?
Regards
The upload method is to use the firmware toolkit, and then upload the m file,
Copy the ui file to the SD card and insert it into the card slot.
Then upload the s file.
