Marlin-1.1.8 (05022018) firmware for I3 A pro
Gingko
Re: Marlin-1.1.8 (05022018) firmware for I3 A pro
Post by Gingko »
_shorty_ wrote: Sat Nov 10, 2018 6:02 am I'm getting this error on arduino software version 1.8.7
U8glib.h: No such file or directory
Put this file in the library and try again,
Sketch->Include Library->Add .ZIP Library.
U8glib.rar
(902.88 KiB) Downloaded 739 times
_shorty_
Post by _shorty_ »
thanks!
You need to add the U8gilb on library manager(Arduino).Then it will work.
flat-jack
Post by flat-jack »
Someone modified the firmware for use with 3D-Touch and get it to work?
flat-jack wrote: Thu Nov 22, 2018 4:11 pm Someone modified the firmware for use with 3D-Touch and get it to work?
You need to check the hardware at first.
If the 3dtouch wires plug correct,the firmware needs to change.
1. Enable the auto level and set the correct value on configuration.h
2.Then you need to set the servo0 pin on board pins.h :D
