Page 2 of 2
Re: Marlin-1.1.8 (05022018) firmware for I3 A pro
Posted: Sat Nov 10, 2018 5:17 pm
by Gingko
_shorty_ wrote: Sat Nov 10, 2018 6:02 am I'm getting this error on arduino software version 1.8.7
U8glib.h: No such file or directory
Put this file in the library and try again,
Sketch->Include Library->Add .ZIP Library.
Posted: Sun Nov 11, 2018 8:27 am
by _shorty_
thanks!
Posted: Tue Nov 13, 2018 1:45 pm
You need to add the U8gilb on library manager(Arduino).Then it will work.
Posted: Thu Nov 22, 2018 4:11 pm
by flat-jack
Someone modified the firmware for use with 3D-Touch and get it to work?
Posted: Sat Nov 24, 2018 10:39 am
flat-jack wrote: Thu Nov 22, 2018 4:11 pm Someone modified the firmware for use with 3D-Touch and get it to work?
You need to check the hardware at first.
If the 3dtouch wires plug correct,the firmware needs to change.
1. Enable the auto level and set the correct value on configuration.h
2.Then you need to set the servo0 pin on board pins.h :D
