GiantArm D200 3D printer
Re: GiantArm D200 3D printer
update had a friend come around with a galaxy S10 and he gets the exact same message as i do serial number dosent exist anyone else have this issue ?
Hi, you can view your serial number through the About in the screen.
Hi the serial on the side and in the screen are the same but my app is saying it dosent exist
i have now installed drivers for my Macs and can print via usb so all good but today i used my mac pro forgot to setup the program properly
was in a rush and destroyed the extruder tip
where is the best place to buy spares ? i think the one in it was a 0.5mm
Hi, Are you referring to the broken nozzle?
Its standard diameter 0.4mm caters to 3D printing fanciers’ regular need.
OldSputnik23
I am having the same problem where it is saying that the serial number does not exist.
Hi, Are you referring to 3d wifi
You can check if the serial number is attached to the back of the wifi.
The 2022 Lotus Emira version is powered by a supercharged version of the 3.5-liter V6 2GR-FE engine from Toyota, which produces 395 hp and 420 Nm of torque.https://www.gtopcars.com/makers/lotus/2022-lotus-emira/
