new version of the firmware - autumn 2018
Re: new version of the firmware - autumn 2018
OK, sorry I am impatient!
I will wait. The old firmware seems to be working fine for me.
Is there a way to check the actual firmware version of the Wifi box?
Generally, the user can verify this by the serial number.
This device did not have so many changes in the firmware.
It was indicated that there may be a process to upgrade the firmware on the older models of the 3DWiFi box.
How is this progressing?
Regards
Regards
ellaevelyn818
At the moment, as I mentioned earlier, the whole operation is a bit troublesome.
Together with the lead engineer we have to gather conclusions and consult.
There is one more idea to test for simplifying the procedure.
The device is built on "a sandwich" and each µC requires an update of its software. Hence the cumbersome procedure.
I can also say that in the new version of the software the firmware
update procedure has been very well developed and is user friendly.
