you think retraction could cause that?William wrote: Mon Nov 25, 2019 3:58 pm Hi, If you print the print model on the picture,
There is no need to turn on the reaction.
And you need level the bed,refer the speed:30-60mm/s.
Layers finish with gaps...
Re: Layers finish with gaps...
I had the same Problem with a new Nozzle 0,4mm,
instead 45-001-0114 , i took 45-005-0114 (MK8)
I adjust the amount of the filament from 100 to 250.
OK
OK
Did you know, what you are doing? If you will continue with similar changes, your printer should be fall to state, from which you did not bring it alive again.
Please read my topic about A10 profile, below.
A10 Slic3r profile: here
