Which numbers of pin is available with pwm?
Sitaylik
Re: Which numbers of pin is available with pwm?
Post by Sitaylik »
It work good but sound on 1-244 is annoying.
Hi, Is it the sound of the cooling fan on the motherboard?
Can you provide specific videos?
Sitaylik
Post by Sitaylik »
Sorry for vertical video.
https://youtu.be/xCEtrG0Q4oE
Hi, It looks like every fan is working.
Sitaylik
Post by Sitaylik »
Yes, it working but im talking about the noise. Not exactly from fan when it cooling. But the noise when the fan controlled by PWM at low values ​​0-38 does not rotate but makes a sound from the pulse frequency of the PWM.
https://youtu.be/peBKzSSdqPE
Hi, I find this:
When the PWM pulse is turned on, the fan torque will change step by step, and the curve of the change process matches the rise time of the PWM pulse.
Shock torque is considered noise by the fan structure.
The lower the PWM duty cycle, the greater the percentage of time the fan is stopped (quiet), so the noise caused by the PWM signal becomes more obvious.
Hi, Q5 position on the GT2560 V3.0 motherboard.
:D
