Hi, you can try to reverse the direction of the motor of the extruder, check the situation,
If it still does n’t work,
It can be installed in the position of the extruder motor using A4988.
maybe not saving the reverse setting of the extruder motor leads to.
TMC2208_extruder problems
Re: TMC2208_extruder problems
William wrote: Fri Apr 10, 2020 5:56 pm Hi, you can try to reverse the direction of the motor of the extruder, check the situation,
It can be installed in the position of the extruder motor using A4998
done.
but the same, the extruder doesn't move, it works only with A4998.
If I change the A4998 with TMC2208 or TMC2209, the extruder doesn't move anymore.
I don't know
