Older version of Marlin firmware are bugged and autoleveling don't work.
I've downloaded last RC (v 1.1.0 RC8) from github, made some changes in "configuration.h" and in "pins_ULTIMAKER.h", compiled and uploaded.
Changes to made in configuration.h
Code: Select all
// The following define selects which electronics board you have.
// Please choose the name from boards.h that matches your setup
#ifndef MOTHERBOARD
#define MOTHERBOARD 7
#endif
Code: Select all
* Select your power supply here. Use 0 if you haven't connected the PS_ON_PIN
* 0 = No Power Switch
* 1 = ATX
* 2 = X-Box 360 203Watts (the blue wire connected to PS_ON and the red wire to VCC)
* :{ 0:'No power switch', 1:'ATX', 2:'X-Box 360' }
#define POWER_SUPPLY 1
Please note that I've the E3D Hotend, CHANGE IT if you have the Geeetech original
Code: Select all
// original definition by GEEETECH
// -->> #define TEMP_SENSOR_0 1 <<--
// DEFINE PER E3D V6 HOTEND AS IN WEB PAGE http://wiki.e3d-online.com/wiki/E3D-v6_Assembly
// 5
#define TEMP_SENSOR_0 5
Search Thomas Sanladerer PID tuning video
Code: Select all
//============================= PID Settings ================================
// DEFAULT PER GEEETECH
#define DEFAULT_Kp 22.2
#define DEFAULT_Ki 1.08
#define DEFAULT_Kd 114
Code: Select all
//============================== Movement Settings ============================
#define DEFAULT_AXIS_STEPS_PER_UNIT {80,80,400,93} // default steps per unit for Ultimaker
#define DEFAULT_MAX_ACCELERATION {3000,3000,20,10000} // X, Y, Z, E maximum start speed for accelerated moves. E default values are good for Skeinforge 40+, for older versions raise them a lot.
#define DEFAULT_ACCELERATION 1000 // X, Y, Z and E acceleration in mm/s^2 for printing moves
#define DEFAULT_RETRACT_ACCELERATION 1000 // E acceleration in mm/s^2 for retracts
#define DEFAULT_TRAVEL_ACCELERATION 1000 // X, Y, Z acceleration in mm/s^2 for travel (non printing) moves
Code: Select all
//============================= Z Probe Options =============================
// The BLTouch probe emulates a servo probe.
// The default connector is SERVO 0. Set Z_ENDSTOP_SERVO_NR below to override.
#define BLTOUCH
// Z Servo Probe, such as an endstop switch on a rotating arm.
//#define Z_ENDSTOP_SERVO_NR 0
//#define Z_SERVO_ANGLES {70,0} // Z Servo Deploy and Stow angles
#define Z_SERVO_ANGLES {10,90} // Z Servo Deploy and Stow angles
// *USE YOUR VALUES*
// modificato da Sergio il 25/02/17
#define X_PROBE_OFFSET_FROM_EXTRUDER -2 // Probe on: -left +right
#define Y_PROBE_OFFSET_FROM_EXTRUDER -20 // Probe on: -front +behind
#define Z_PROBE_OFFSET_FROM_EXTRUDER -2 // -below (always!)
// X and Y axis travel speed (mm/m) between probes
// #define XY_PROBE_SPEED 8000
#define XY_PROBE_SPEED 1000
// Enable Z Probe Repeatability test to see how accurate your probe is
#define Z_MIN_PROBE_REPEATABILITY_TEST
// #define Z_CLEARANCE_DEPLOY_PROBE 10 // Z Clearance for Deploy/Stow
#define Z_CLEARANCE_DEPLOY_PROBE 5 // Z Clearance for Deploy/Stow
#define Z_CLEARANCE_BETWEEN_PROBES 5 // Z Clearance between probe points
Code: Select all
// @section machine
// Travel limits after homing (units are in mm)
// #define X_MIN_POS 0
// #define Y_MIN_POS 0
// #define Z_MIN_POS 0
// #define X_MAX_POS 200
// #define Y_MAX_POS 200
// #define Z_MAX_POS 200
// MY SETTINGS
#define X_MIN_POS 0
#define Y_MIN_POS 0
#define Z_MIN_POS 0
#define X_MAX_POS 195
Code: Select all
//#define AUTO_BED_LEVELING_3POINT
//#define AUTO_BED_LEVELING_LINEAR
//#define AUTO_BED_LEVELING_BILINEAR
// Set the boundaries for probing (where the probe can reach).
// #define LEFT_PROBE_BED_POSITION 15
// #define RIGHT_PROBE_BED_POSITION 170
// #define FRONT_PROBE_BED_POSITION 20
// #define BACK_PROBE_BED_POSITION 170
#define LEFT_PROBE_BED_POSITION 30 // 15
#define RIGHT_PROBE_BED_POSITION 180
#define FRONT_PROBE_BED_POSITION 40
#define BACK_PROBE_BED_POSITION 180
Code: Select all
// - Allow Z homing only after X and Y homing AND stepper drivers still enabled.
// - If stepper drivers time out, it will need X and Y homing again before Z homing.
// - Move the Z probe (or nozzle) to a defined XY point before Z Homing when homing all axes (G28).
// - Prevent Z homing when the Z probe is outside bed area.
#define Z_SAFE_HOMING
Code: Select all
// EEPROM
// The microcontroller can store settings in the EEPROM, e.g. max velocity...
// M500 - stores parameters in EEPROM
// M501 - reads parameters from EEPROM (if you need reset them after you changed them temporarily).
// M502 - reverts to the default "factory settings". You still need to store them in EEPROM afterwards if you want to.
//define this to enable EEPROM support
#define EEPROM_SETTINGS
Code: Select all
// SD CARD
// SD Card support is disabled by default. If your controller has an SD slot,
// you must uncomment the following option or it won't work.
//*MOD*
#define SDSUPPORT
Code: Select all
// Number of servos
// If you select a configuration below, this will receive a default value and does not need to be set manually
// set it manually if you have more servos than extruders and wish to manually control some
// leaving it undefined or defining as 0 will disable the servo subsystem
// If unsure, leave commented / disabled
//#define NUM_SERVOS 3 // Servo index starts with 0 for M280 command
#define NUM_SERVOS 1
Changes to made in pins_ULTIMAKER.h
Code: Select all
// Servos
// #define SERVO0_PIN 13 // untested
#define SERVO0_PIN 32 // 12
// Limit Switches
#define X_MIN_PIN 22
#define X_MAX_PIN 24
#define Y_MIN_PIN 26
#define Y_MAX_PIN 28
#define Z_MIN_PIN 30
// #define Z_MAX_PIN 32
#define Z_MAX_PIN -1
