electronic got fried
zhangxueyou
Re: electronic got fried
Post by zhangxueyou »
Did you choose correct board type(Sanguinololu W/AT mega1284p 16mhz) and serial port?
Do you use our firmware?
ash2k14
Post by ash2k14 »
Yes the board and port were correct as well, but I got that error when I wanted to upload the firmware, I believe that the atmega1284p doesn't have a bootloader, thus I'm unable to upload the firmware
zhangxueyou
Did you install the driver?
If not, you should install it first.
ash2k14
Post by ash2k14 »
Yes, driver properly installed without problems, no yellow exclamation mark. The usb cable are fine because there were no disconnections detected.
Pronterface unable to connect
Repetier host didnt show firmware details
ash2k14
Post by ash2k14 »
Yes, it has been installed, no yellow exclamation mark, com port also left as it is, during connection, correct com port also picked
ash2k14
Post by ash2k14 »
Yes i did, there were no problems with the driver, no yellow exclamation mark appeared in the device manager
Regarding my tech support on the board, how lomg am i supposed to wait? And another thing, how many posts should i submit to get the post approved. My supports are slow due to posts being approved at lower rate and yet, my time is running out in aliexpress. The wholr printer cannot function and testing it is impossible without the electronic
zhangxueyou
What is your computer system?
ash2k14
Post by ash2k14 »
windows 7 ultimate 64 bit
core i5
ati mobility radeon5650 1gb vram
4gb ram
500gb hdd
4 usb port
zhangxueyou
ash2k14
Post by ash2k14 »
The software failed to connect just like how I used the normal repetier host. Refer to the picture below
