Prusa i3 acrylic extruder ticking
k3tzor
Re: Prusa i3 acrylic extruder ticking
Post by k3tzor »
zhangxueyou wrote:
k3tzor wrote:
zhangxueyou wrote:1. Swap the exturder motor driver(A4988) with x or y motor driver. Check if the extruder motor works after heating. (To check if extruder motor driver is broken)
2. Plug x or y motor to extruder connector, check if the motor works after heating. (To check if extruder motor is abnormal)
  1. Already tried that with some new stepper drivers
  2. This does the same, so this is strange.
Today the test went a bit better, but the extruder motor isn't that strong enough seems to be. When it's starting a new print, and it went a bit cold, before it would have a clog. When i try pushing it trough before the print. Try it again, print starts up, but then suddenly in the middle of the print it starts ticking again.. So how come????? I was making progress, and now it's in the middle of a print :x
What is temperature reading when it's ticking?
Tried printing a shot glass. Went allright in the beginning, but then half of the print it started ticking..
Here is an album with the images, as you see in the middle and at the top:
http://imgur.com/a/9A8FX
These are my slic3r settings:
http://imgur.com/a/PPRpN
So i can not finish a good print .. Waist of filament...
zhangxueyou
Post by zhangxueyou »
Is the cooling fan working when printing?
k3tzor
Post by k3tzor »
Yes the cooling fan is working while printing. Printer is working like it should only the extruded is broken then because it always ticks........
k3tzor
Post by k3tzor »
zhangxueyou wrote:Is the cooling fan working when printing?
Tried it without the fan, and still doesn't work.. Maybe there is a defect??
zhangxueyou
Let the fan keeping working when printing. How about the slicer setting?
k3tzor
Post by k3tzor »
zhangxueyou wrote:Let the fan keeping working when printing. How about the slicer setting?
Like I posted in my other post.. Here are the settings http://imgur.com/a/PPRpN
So srsly I'm just waisting filament by that the printer isn't working :/
k3tzor
Post by k3tzor »
Still not working.. And no support anymore from you guys :/
zhangxueyou
k3tzor wrote:Still not working.. And no support anymore from you guys :/
Please rotate the screw clockwise on extruder motor driver, the voltage between screw and GND should be up to 1V.
k3tzor
Post by k3tzor »
Already tried it, the ticking goes faster and slower. But still doesn't load the filament properly.. Maybe the system isn't compatible with 3MM ?
zhangxueyou
Oh, jesus, I ignored this point! I am so sorry.
Yes, if you want to print with 3mm filament, you need to change the extruder.
You can try 1.75mm filament.
Sorry for wasting your so much time.
