All the heatbed wires are insulated as sent by the seller, no short circuit is present. After reading a lot about this topic I can say:
At the beginning of the topic I told you that the heatbed resistance is too low (0.2 ohm) compared to normal values (1 - 1.5 ohm). Considering the voltage provided by the power supply 12 V and the heatbed resistance of 1 ohm, the current required is 12 Amp. which is common. For a heatbed resistance of 0.2 ohm (SHORT CIRCUIT) and voltage of 12 V, the current required is 60 Amp, which exceed the limit of power supply (15 Amp), this is the reason why the mainboard us burnt, hope the power supply did not burnt also. Please review all our conversation.
I am waiting for a solution. Thanks for your attention.
Heatbed MK2a does not work
Re: Heatbed MK2a does not work
Please conntact customer service.
And please leave your purchase link and order number.
