axis problem
Re: axis problem
I mean that i tryed what you sayed to swap motor x with extruder and it works, but when i try to print with the extruder in his own driver slot nothing happend.
Re: axis problem
Can you extrude the filament with your hand?
Re: axis problem
you mean pushing the flament in the hole? nope i cant.
Re: axis problem
After you raise the temperature properly but you can extruder the filament by your hand, you should check if the nozzle is jammed.
Re: axis problem
but when i push the filament with the right temperature it doesn t melt. and when i try to print something its like the extruder motor dosen t move at all.
Re: axis problem
Sorry, I was to say"After you raise the temperature properly but you can extruder the filament by your hand, you should check if the nozzle is jammed.
After you raise the temperature properly but you can not extruder the filament by your hand, you should check if the nozzle is jammed."
Is the nozzle too close to the bed that the filament can not come out?
If not, please refer to this page to clear the nozzle:
http://www.geeetech.com/forum/viewtopic ... 19&t=16414
Re: axis problem
i tryed your link to clear my nozzle. i got the nozzle form the extruder raised the temperature to 240 degree and i tryed to push the filament. it came out a bit but after sometimes its just stoppend and pushing the filament it broke inside the nozzle .
