Prusa i3b PLA clicking after a while
Re: Prusa i3b PLA clicking after a while
Could be the same problem that in this thread? http://www.geeetech.com/forum/viewtopic ... 19&t=18010
I can confirm that it's an extruder design problem:
I put an element to block the pressure system and then it worked again. What can we do? Extruder replacement?
Regards
Regards
Hi,stark0 wrote:I can confirm that it's an extruder design problem:
Regards
It is weird,i can't see your pic...Since that,i guess it's the bad spring caused this.To solve the problem,you can contact the seller resend you serveral springs,and it may work.
Regards
after replacing the feeder system for the old one I can confirm that the feeder was the problem. Now I'm able to print 10+ hours without problem in PLA and I'm happy with the printer.
Regards!
Regards!
FernandoGarcia
Hi!stark0 wrote:Hi,
Regards!
Are you talking about aluminum version?
Best regards.
yes, I replaced this one: http://www.geeetech.com/mk8-extruder-fe ... 8tfefcp3u5
for this one:
http://www.geeetech.com/mk8-extruder-al ... p-995.html
Regards
for this one:
Regards
I got the same problem with my MK8 2. Had to adjust the spring tension with washers. By design my tension can't be higher by now. It will hit the stop.
I'm looking at this solution. Do we buy the short or the long one? I can't find an explanation of the differences. Thanks!stark0 wrote:Hi,
for this one:
Regards
