WiFi module does not connect to my router
Re: WiFi module does not connect to my router
Hi.
I suggest you write a protest to your Internet service provider.
It is not okay that you have limited access to services :!:
francko76
Post by francko76 »
_kaktus_ wrote: Thu Jan 10, 2019 1:27 am Hi.
I send 2 mails
1 to the mail address that you gave me (geeetech)
1 to my provider
Both didn't replied me.... After 3 days
Hi.
In this area, I do not see an error on the program side. :roll:
The application is blocked by a stupid filter of the Internet provider.
This should not happen. :cry:
francko76
Post by francko76 »
_kaktus_ wrote: Thu Jan 10, 2019 4:04 am Hi.
True, by maybe they could operate adding another port ...
ichund3d
Post by ichund3d »
I 'm new here and I have nearly the same problem. I tried a lot to connect my 3D WiFi module to my network. Connection to
printer is okay, I have also access from app to module. Only the connection to my router fails. I tried to connect to 2 routers, same result:
"Wi-Fi config is fail"
Entry of SSID and password is correct, using WPA + WPA2, 2,4GHz, free to connect new devices. Level of quality is good.
I found out the MAC address of the WiFi module and manually added the device to my network. So I was able to open the port 5000 to the device. Unfortunately this didn't solve the problem. The connection is always fail.
I also tried a different approach. With another mobile phone I built up a WiFi spot and tried to log in the WiFi module there. The same result there.
I got a second WiFi module, even not able to connect. What is wrong, I have no idea.
Please help me, I 'm lost.
francko76
Post by francko76 »
ichund3d wrote: Sat Feb 02, 2019 7:04 am Hello,
If your home router has a closed 5000 you can try to open that port going in router settings.
My Home provider has that port always closed, so I can't use WiFi Module.
I wrote to geeetech support and they told me to buy a raspberry and use octoprint :|
I bought a wifi module from geeetech and I have to trash it....
Actually I bought a Pi3B+ and I'm happy with Octoprint
ichund3d
Post by ichund3d »
My knowledge in network is limited. Is it not possible to open port 5000 inside my home network only? At my FritzBox I can open port 5000 for the module, but it doesn't solve the problem. I do not need access from "outside".
Raspberry and use of octoprint is no option for me yet. It is too much effort.
Hi.
:mrgreen:
ichund3d wrote: Mon Feb 04, 2019 7:28 am ...
Your new hardware needs it.
For your convenience, you can ask your internet service provider whether they have blocked communication over the internet on this port.
cmighells
Post by cmighells »
This board appears to be dead with most answers being from 2018. I too need help and hope I will get a helpful response here. After connecting to the module hotspot I get a message saying the wifi setup was successful. Then I get an error saying the server is not available and the process has to be started all over. What needs to happen or do I need to send this back? Thanks in advance.
:D Hi, for the use of the wifi module,、
you can refer to this: https://www.youtube.com/watch?v=FguzMjI ... e=youtu.be
If so, you check if your wifi is around 2.4.
