Locked
symowallo
Post by symowallo »
So I take it that's a "No, we aren't going to do this, please work it our for yourselves"?
Yves
Post by Yves »
I there a newer version for I3 PRO B ?
Since I have replaced the original one (printer is from Dec. 2017) by this one, the SD card does not function anymore, nor the turn button. Thanks
You can upload the old version and you will get the result the sd card works or not, you need inserts it to printer again
[quote=Mark post_id=27625 time=1444446141 user_id=47216]
Hi guys, all the firmware for geeetech 3D printers are here,
please choose your printer type download it, tks!
[i][size=130] 1) Firmware for [url=http://www.geeetech.com/geeetech-prusa- ... p-965.html]Prusa I3 M201[/url][/size][/i]
The latest version(for GTM32) :
GTM32_V1.0.5.zip
[color=#FF0000]For the new board(GTM32 Pro)on M201:[/color]
gtm32_machine_m201.zip
Note:
V1.0.5 added some G-code commands on the base of V1.0.4:
M92: Set axis_steps_per_unit
M110: Set Current Line Number M500
M502: Revert to the default "factory settings."
M300: Play beep sound
M304: Set PID parameters - Bed
V1.0.4 has fixed some bugs and the pause problem in the old ones, check out this link for more details:
viewtopic.php?f=20&t=17279
The old version:
GTM32_V1.0.4.zip
GTM32_1.0.3.zip
GTM32-V1.0.0.zip
GTM32-old.zip
[/quote]
I just bought a new M201 printer. It has a GTM32 Pro VB controller board.
I am asking for clarification.
@Mark you are writing:
[quote] [color=#FF0000]For the new board(GTM32 Pro)on M201:[/color] [/quote]
Does it mean GTM32 Pro VB?
I think that this is key information and should be presented precisely.
Have a nice day.
Mark probably does not look at this forum anymore ...
Can any of the staff respond to my doubts?
I will check it at now
[quote=William post_id=82045 time=1516003735 user_id=51382]
[/quote]
Any good news in the subject?
keyser187
Post by keyser187 »
i have just downloaded the firmware for the pro w and installed it but now my motors dont move?
if i disconnect the printer from the usb it seems to work fine, i can auto home but when i load repetier host and connect, nothing seems to work anymore.? if i press the buttons to move manually i can see the motors trying to move especially the y and z?
im a complete noob to all this btw so sry in advance.
really annoying now as it was working fine until i tried to update the firmware now i have a broken printer that i only got a week ago!!!!!!
correction, the motors dont move at all even when disconnected from usb
You should upload it again and check the firmware is correct.
keyser187
Post by keyser187 »
thx for the reply.
ive already tried a few times and same result. i also tried to install the repetier firmware but that just kept giving out loud beeps and nothing worked at all?
Locked
