SKR V1.3 on the A10 - Any pointers?
derekpittx
Re: SKR V1.3 on the A10 - Any pointers?
Post by derekpittx »
I have an SKR 1.3 on the way, arriving Monday since it was actually cheaper to upgrade than to replace. I'll probably step up to the TMC2130's at some later date but for now it's just a straight-up replacement of the GT2560 v3 I'm after.
gopher
Post by gopher »
Great! Waiting for some news 8-)
krankins
Post by krankins »
gopher wrote: Wed Jul 01, 2020 7:19 pm Great! Waiting for some news 8-)
it's out now! :) tubemate mobdro
gopher
Post by gopher »
Hm, where?)
dhanushx012
Post by dhanushx012 »
I also seem to have randomly encountered a wiring fault in my X endstop wherein the wrong two wires are bundled (+5 and G instead of +3.3 and G as in every other switch) and my connectors are reversed. The excess voltage causes the board to shutdown every time the X stop is touched and I'm not exactly sure why that fault didn't show up with the GT2560 installed, just a baseline difference between ATMega and SAMD controllers I imagine.
Kzerafa87
Post by Kzerafa87 »
im in the process of doing the upgrade myself and have encountered the same issue i have discovered the Limit Switch's have LEDs on the boards, reversing the Outer 2 pins on either end of the limit cables solves this problem of the board rebooting, what's happening when the switch is pressed is its shorting out the 5v on the board causing it to shut down, just use a small pointy object to release the cables in the JST connecter and flip em
sainivedant41
Post by sainivedant41 »
I have the board in-hand now. I've flipped the jumpers to support the A4988 drivers I already have. I'm plodding my way through the Marlin 2.0 PlatformIO issues including an undocumented requirement to reboot the board *twice* for a firmware installation instead of just once which I had to find in a Github search. There's an Ender3 config available which I'm using for a baseline.
Justjay
Post by Justjay »
Hi guys
I've got an a10 Pro and just fitting an btt skr e3 v1.2 and touch screen tft whiuc matches. Struggling a little bit firmware wise, think I'm having a bit of a brain fog.!
Is anyone able to point me in the correct direction of this firmware? I've compiled and flashed previously and I'm OK with it, this is just stumping me!
Thanks!
Justjay
Post by Justjay »
Managed to sort the firmware but can't get any endstop to work.... Any thoughts?
jazz0000
Post by jazz0000 »
we are providing the jazz call and ufone call packages with detail
