Page 5 of 7
Re: acrylic I3 motor issues
Posted: Mon Mar 09, 2015 8:11 pm
by buzmal
Ok I am still having extruder flow issues, in order to get the extruder to work at all i need to head the extruder to 230, my estep it set to 100, I am using 3mm pla.
The extruder will initally flow but blocks after a few minuets of printing an actual soloution would be good.
Posted: Mon Mar 09, 2015 8:28 pm
by buzmal
here is a picture of the latest print i tired, as you can see the print started but becomes stingy and lumpy and the extruder blocks causing the motor to pulse.
Posted: Tue Mar 10, 2015 9:22 am
by zhangxueyou
I am so sorry, I ignored something, If there is a big gear on the extruder, the Estep is 760, otherwise, the Estep is 95.
Please take a picture.
Posted: Tue Mar 10, 2015 9:43 am
by buzmal
I have the mk8 I'll try turning the ester down from 100 to 95. If I manually extrude it works we and will extude smoothly.
Posted: Tue Mar 10, 2015 9:54 am
by zhangxueyou
Could you please take a picture?
Posted: Tue Mar 10, 2015 10:50 am
by buzmal
I can what do you need a picture of the pic in the above post is of the printing results I have had on my last print. If you need a pic of something else I will post it when I get home.
Posted: Tue Mar 10, 2015 11:08 am
by zhangxueyou
I thought of my experience, which is similar to you.
There are two things you should do:
1. Check the Estep.
2. Check your slic3r settings.
Posted: Tue Mar 10, 2015 12:10 pm
by buzmal
What are the slicer setting I should be using for 3mm pla wih the .4mm nozzle
Posted: Tue Mar 10, 2015 1:44 pm
by zhangxueyou
It is at the right side of Repetier: Tab"Slicer">the first "Configure".
Posted: Tue Mar 10, 2015 2:28 pm
by buzmal
Yes I know where that all is but what settings exactly am i supposed to be using.
