Page 5 of 6
Re: For people who wants STL files of parts
Posted: Thu Jan 19, 2017 5:43 pm
Hi,@KiloVolT
Could you please attach a picture of the mentioned part?
Maybe i can help you get it.
Posted: Mon Mar 06, 2017 4:41 pm
by x20011
Does the PI3B-B03 carriage fit for the "Geeetech i3 Pro C".
I want to change my Dual direct drive extruder to Single bowden extruder with Autobed Level....
Posted: Wed Aug 23, 2017 6:43 pm
by leonmarkus
Are there some .stl files available for the METAL parts of the newer Geeetech Prusa i3 Pro B?
Would be really handy for designing things in CAD.
Thank you!
Posted: Thu Aug 24, 2017 4:29 pm
There are no STL files for new Pro B.
Posted: Tue Aug 29, 2017 1:16 am
by Lami René
Bonjour,
Voici quelques pièces pour l'imprimante 3D Delta Geeetech Rostock 301 :
https://www.thingiverse.com/thing:2464177
Voir aussi :
http://forums.reprap.org/read.php?178,781375,781375
L'ami René
Posted: Wed Dec 06, 2017 7:04 pm
by JustinSB
I have a Pro W (which is, of course, cut from plywood). If I want to modify/upgrade/add bits, does it have the same fittings as the Pro B...? If not, what should I use instead?
Posted: Sun Mar 11, 2018 4:52 pm
by gyany_eugen
Hello.
I have a Geeetech I3 Pro W (wood frame) and I need stl files for Y belt holder. At least the only piece which is from plywood.
Is there any chance to find stl files for this printer?
Thank you!
Posted: Mon Mar 12, 2018 6:51 pm
gyany_eugen wrote: Sun Mar 11, 2018 4:52 pm
Hello.
Thank you!
I will check ,if I have this part stl files. I will send it to you.
Posted: Sat Nov 03, 2018 6:30 am
by moi
hi can anyone yell me if there is a stl available for the i3 pro b acyrilic z motor frame part, i broke one during assembly, really would appreciate some help to find this part to print.
best regards
Posted: Sat Nov 03, 2018 4:57 pm
by _kaktus_
Hello.
Enter the part number & show photos of the required item. I will see what can be done.
