Page 1 of 2
avrdude: stk500_getsync(): not in sync: resp=0x00
Posted: Fri Jan 23, 2015 6:37 pm
by Igor
Hi.
OS: Win7 64 bit
Arduino software v0022
Azteeg 3D Printer Controller Atmel ATmega 644P with FT232RL FTDI USB chip
1. When I trying to upload MARLIN firmware following error appears:
Binary sketch size: 51518 bytes (of a 63488 byte maximum)
avrdude: stk500_disable(): protocol error, expect=0x14, resp=0x51
2. Tried with 3 different USD cables - same error
3. Seems like Port and Board types appears correctly in Arduino software
4. When I'm trying to upload boot loader with USBtinyISP following error appears:
avrdude: Expected signature for ATMEGA644P is 1E 96 0A
Double check chip, or use -F to override this check.
PLEASE HELP ME TO SOLVE THIS ISSUE !!!
Re: avrdude: stk500_getsync(): not in sync: resp=0x00
Posted: Mon Jan 26, 2015 3:35 pm
by kris.mao
Dear friend,
1. Before downloading the program, please disconnect all the devices.
2. Connect the board to the PC, when detects Com port, choose correct Com port in Arduino IDE.
3. Please download" Sanguino Patch for Windows" at:http://www.geeetech.com/wiki/index.php/Azteeg . And put the decompressed files to the hardware folder which is under the installation directory of Arduino IDE. Then try to burn it.
Best regards!
Posted: Tue Jan 27, 2015 2:57 am
by Igor
I try it already and it's still doesn't working.
Posted: Tue Jan 27, 2015 8:08 pm
by kris.mao
Dear friend,
When appears error“avrdude: stk500_getsync(): not in sync: resp=0x00
avrdude: stk500_disable(): protocol error, expect=0x14, resp=0x51”, the general reason are wrong selection of mother board type and COM port.
if they are correct, please try to reburn Bootloader:
1.Make sure that ISP has been connected correctly.
2.Decompress file “Sanguino Patch for Windows”, and put the decompressed file to "hardware" under intallation directory of Arduino IDE(Arduino->Hardware).
3.Open Arduino IDE, choose Sanguino W/ ATmega644P.
Tools / Programmer / USBtinyISP
Tools / Burn Bootloader
Please kindly try this!
Posted: Sun Feb 01, 2015 2:48 am
by Igor
Actually I'm working on this issue. I want completely re install my OS and start from scratch. Also I will create some video and add it to my next post. Thanks for now.
Posted: Tue Feb 03, 2015 9:10 am
by john
Hi Igor,
Have you fixed your promblem?
Posted: Tue Feb 03, 2015 6:11 pm
by Igor
Hi. Still not, as I said before I working on video in order to describe my problem, hopefully I will finish it today.
Posted: Wed Feb 04, 2015 4:34 am
by Igor
Still doesn't working. Please watch my video about this issue: https://www.youtube.com/watch?v=Xw6BYYaCDMI
Posted: Thu Feb 05, 2015 11:46 am
by john
We are sorry about this.
After watching your video, I tried to repeat your problem and I think I know the reason. I think you chose a wrong board in "Tools/Board" becouse of our wrong guide on wiki page. The right board is 'Azteeg X1 v1.5 W/ ATmega1284p 16Mhz', We used ATmega644p at the beginning, The guide was too old. I'm sorry again for our carelessness. And thank you point out our mistake.
Desire your feedback.
John
Posted: Sat Feb 07, 2015 3:29 am
by Igor
1. It's works now, thanks for help (please update your documentation/info) !
2. But now I have another problem - when HOTBED is connected (even there is no power input + USB/board is connected to PC) for some reason fuse (that related to hotbed) becomes extremely hot... what wrong now ? Maybe wiring diagram is not correct... ? (using this one: http://www.reprap.org/wiki/File:X1_wiring_diagram.jpg)
