Rostock Mini measurements
Posted: Sat Feb 21, 2015 10:28 pm
I was wondering if someone could provide me the delta section of the configuration.h used in the firmware for the Delta Rostock mini. Specifically, based off of the model design, I want to get the values in milliment for the the following variables describing the delta build settings. As many digits of accuracy as you have.
DELTA_CARRIAGE_OFFSET (distance from the carriage side joint center to the centerline of the smooth rod the carriage sits on)
DELTA_DIAGONAL_ROD (distance on the arm from the carriage side joint to the effector side joint)
DELTA_EFFECTOR_OFFSET (distance from the effector side joint to the center of the effector [holder of the hotend])
DELTA_SMOOTH-ROD_OFFSET (distance of the center of the rod, to the true center of the bed)
DELTA_RADIUS (assuming all carriages are level and the effector is centered over the center of the bed. It is the length of the adjacent or bottom line formed by creating a 90 degree angle where the bottom join (horizontal) intersects the top joint (vertical). It would be the length of the center of effector to the 90 degree corner.)
These values should already be in the firmware you provide, but I am wanting to put some updated features into the marlin firmware. I can measure these, but I would imagine that has already been done by your engineering department.
