I3 acrylic X and Z wrong way
Posted: Thu Apr 09, 2015 1:01 am
by hugues
Hi.
Just finished assembly of my acrylic prusa I3.
The Z axis is going the right way (down when pressing home)
But the Y axis and the Z axis are going in the opposite of the endstops.
I tried both repetier and the control panel.
What do I do?
inverts cables?
thanks for your reply
Re: I3 acrylic X and Z wrong way
Posted: Thu Apr 09, 2015 8:46 am
by zhangxueyou
Yes, you can try to invert cables.
Re: I3 acrylic X and y wrong way
Posted: Thu Apr 09, 2015 1:28 pm
by hugues
Ok.
Do I invert it by pairs? do i also invert colors?
thanks.
Posted: Thu Apr 09, 2015 1:37 pm
by zhangxueyou
Invert the cable of motor which goes wrong way.
Re: I3 acrylic X and Y wrong way
Posted: Fri Apr 10, 2015 12:31 am
by hugues
Ok.
So the wires are actualy
Black - Green - Red - Blue.
How do i invert it?
Blue - Red - Green - Black?
or
Red - Blue - Black - Green?
Posted: Fri Apr 10, 2015 9:22 am
by zhangxueyou
Yes , blue,red,green,black.
Just unplug the cable, roate it for 180°, and plug it.
Posted: Sat Apr 11, 2015 12:53 am
by hugues
The sockets are equipped with a "keyed system" (<-Google trad?), so I had to make a small adapateur but that's it, it works!
Thank you! Problem solved.
A problem once, now I'll find out why the extruder does not work manually.
Posted: Sat Apr 11, 2015 9:44 am
by zhangxueyou
The extruder motor can not move unless the temperature of extruder is more than 175 degrees.
Posted: Sat Jan 28, 2017 12:07 am
by kelderkold
in Repetier_host under the printer settings / Printer shape you can change the home location on the ones you think is driving the wrong way
