Page 1 of 2
extruder motor in i pro c not working
Posted: Thu Jun 25, 2015 4:06 am
by Ahmad2015
I triad every thing in the forms but no use I think it's software issue, I have even switch the control ships but no extrude
can you send me the software for i pro c and how to install it my email is
zx280f40@gmail.com
thanks for your support
Re: extruder motor in i pro c not working
Posted: Thu Jun 25, 2015 9:06 am
by zhangxueyou
Hi, the firmware has been sent to your email.
Have you raised the temperature to 180 degrees? Is it moving with no filament?
Posted: Thu Jun 25, 2015 1:24 pm
by Ahmad2015
yes I raised it to 180c but no extruding When go back home I will try to install the firmwar
thanks agine for your support.
Posted: Fri Jun 26, 2015 3:11 am
by Ahmad2015
installing not possible in ubuntu Linux can adruino get error can you help
temperature.cpp: In function ‘void manage_heater()’:
temperature.cpp:675:1: error: unable to find a register to spill in class ‘POINTER_REGS’
temperature.cpp:675:1: error: this is the insn:
(insn 95 94 97 4 (set (reg/v:SF 103 [ pid_input ])
(mem:SF (post_inc:HI (reg:HI 146 [ ivtmp.209 ])) [4 MEM[base: _110, offset: 0B]+0 S4 A8])) temperature.cpp:459 99 {*movsf}
(expr_list:REG_INC (reg:HI 146 [ ivtmp.209 ])
(nil)))
temperature.cpp:675: confused by earlier errors, bailing out
Posted: Fri Jun 26, 2015 9:19 am
by zhangxueyou
Posted: Fri Jun 26, 2015 10:35 pm
by Ahmad2015
I try it many times I get the same error arduino reading the board no issue but uploading I get error
Posted: Sat Jun 27, 2015 4:21 pm
by zhangxueyou
You are using Linux? Please refer to this page to upload the firmware:
http://www.geeetech.com/forum/viewtopic ... 20&t=16318
Posted: Sun Jun 28, 2015 3:27 am
by Ahmad2015
1/I checked every thing is ok only one drive ship I put to ex2 the voltage
for it max 0.58
2/ installed the firmware you sent successfully
3/ try to move extruder both at 240c with and without filament but no use
4/ put extruder motors to x axis and they working well
5/ in LCD extruder control show only extruder no 1 or 2
I waste one week to move extruder alone and I can't print anything
any solution thanks
Posted: Mon Jun 29, 2015 10:02 am
by zhangxueyou
Is 0.58 got from A4988(the voltage between screw on A4988 and GND)?
How is it when you exchange extruder motor driver with x motor driver(A4988)?
You can control both extruder on Repetier-Host, referring to this page:
http://www.geeetech.com/forum/viewtopic ... 21&t=16512
Posted: Mon Jun 29, 2015 1:01 pm
by Ahmad2015
zhangxueyou wrote:Is 0.58 got from A4988(the voltage between screw on A4988 and GND)?
yes I did all this but no use any idea how to check if the gt2500 board is dameg in extruder motor connection area
thanks
