Bad crafted parts
Posted: Tue Jul 07, 2015 11:27 am
by strannick
Delta Rostock Mini G2 with GT2560
bolt cannot hold rod firmly because rod-end bearing holder is longer for about 1mm. This happened for all rod-end bearing holders
Re: Bad crafted parts
Posted: Tue Jul 07, 2015 11:58 am
by Sherry
hiļ¼please screw up the nut on the rod.if so,the bolt can hold firmly.
Posted: Tue Jul 07, 2015 12:37 pm
by strannick
it is not about rod nut. it is about rod-end bearing holder which is longer than bearing hole, see cross section:
Posted: Thu Jul 09, 2015 10:33 am
by Buzz
I am new just getting into 3D printing and got a G2S. Joining this forum to get information and advice. I didn't see further reply from Geeetech on this. I got the same problem and I cut off 1mm at one end of the bearing.
Posted: Thu Jul 09, 2015 4:38 pm
by Sherry
hi,we have improve what you mention in the post ,please pay attention to our new delta rostock mini.Thank you for your advice.
Posted: Fri Jul 10, 2015 1:28 am
by strannick
Eric wrote:hi,we have improve what you mention in the post ,please pay attention to our new delta rostock mini.Thank you for your advice.
I'm glad to hear that, but what am I suppose to do with that problem??
Posted: Fri Jul 10, 2015 9:16 am
by Sherry
strannick wrote:Eric wrote:hi,we have improve what you mention in the post ,please pay attention to our new delta rostock mini.Thank you for your advice.
please do as what buzz has said , you can cut off 1mm at one end of the bearing.and it will be more firmly
Posted: Sat Aug 15, 2015 12:21 am
by flamtap
It's not a cheap solution, but I ordered 6 packs of these: 6 x 8 x 0.2mm shims.
http://www.advantagehobby.com/245343/TK ... SCT410-10/
I put 5 of them (for 1mm) on each rod-end bearing holder before putting on the rod-end. When the screw is tightened there is no more slop and it doesn't interfere with the range of motion of the rods.
flamtap
