Power Supply
Posted: Sat Dec 19, 2015 7:22 pm
I just finished assembling everything, after the wiring was completed I powered it on. LCD was working fine BUT while I was navigating through the menus on the screen the printer just switched off. I unplugged it and removed the supply for the control board, then I plugged it again (without the control board being wired) and switched it on, the led in the switch is ok but the green led on the power supply is not on.
Any tips?
PS: I checked and double checked the wiring just in case but everything is OK, same for the 110/230 switch in the power supply.
Any tips?
