Acrylic Geeetech I3 pro - Problem with Z Axes
Posted: Fri Jan 29, 2016 7:36 am
Hi everybody, from a few days I have a problem with the Z Axes of my Acrylic Geeetech I3 pro .
After that I have regulated the height of the nozzle respect at the bed with a sheet of paper in the four corner, I make start the print but the nozzle is very much higher than the adjustment made before.
I tried to flash the firmway of the board GT2560, but the problem is the same.
Before I always used the printer without any problem, the print was perfect but at the suddenly it began to make these problems.
I tried to print using the SD card, thinking it was a problem of the PC, but the same thing happens
You can help me to solve the problem?
I forgot to mention that, as If I remeber correctly, it all happened after a blackout of a few seconds that stopped a printing
