Erradic behavior on M201
Posted: Sun Mar 13, 2016 2:30 pm
O several occasions I have started to print and the printer homed in and just sat there or it would move to the initial position for the part to be printed , the only thing I knew to do was shut it down then start over. Also other times when I got a decent looking print going and Z axis reaches a height of 20 to 30 mm x and y axis both start making very rapid moves in both x and y directions, z axis is moving like it is supposed to. I disassembled x and y axis assemblies looking for anything that might be binding up ,but found nothing that could cause that. I've destroyed 7 or 8 prints in a row this way .
I also re-installed Ver 1,0.4 firmware and the usb driver and Repetier Host just in case something had corrupted itself in the process .
Any suggestions ?
Any suggestions ?
