Geeetech Prusa I3 M201, X and Y motors shift
Posted: Tue Mar 15, 2016 2:50 am
I have a problem when i print for a longer period (around 7 hours). I get a unwanted shift in the x and sometimes the y stepper motors.
I check the voltage on the GTM32+5 A4988 board as in this post:
http://www.geeetech.com/forum/viewtopic ... 13&t=17038
The voltage was to low. And leveld them to 1volt with the screws. After that it did not occure that often. But after printing longer than 6 to 7 hours. It still happens that the x motor shifts. So i get crooked prints.
In the image on the post:
It says that the two connections at the top should read 5 volts. But if i measure them i get 3.5 volts. Could that be the problem? And is there a way to adjust that voltage?
Kind regards,
Barry.
Kind regards,
Barry.
