Page 1 of 2
Not printing on bed
Posted: Thu Apr 07, 2016 10:22 pm
by mini
My G2S is not printing on bed , it does all the actions about 200mm above the bed ,movements ,extruding etc could someone please help to solve this problem . I have been trying to get my first print from this printer for over s week ,having to sort various issues , I believe I have done the necessary setting up correct
Thanks Brian
Re: Not printing on bed
Posted: Thu Apr 07, 2016 10:59 pm
by Mark
Did you define the initial Z axis height and then calibrate the bed and nozzle according to the user manual?
Posted: Thu Apr 07, 2016 11:29 pm
by mini
yes it is 207mm
Posted: Fri Apr 08, 2016 12:41 am
by mini
I believe that it is correctly calibrated
Posted: Fri Apr 08, 2016 10:58 pm
by Mark
when you manually move down the nozzle to just touching the bed on all the 3 coordinates and the center point of the bed, what's the readings of the Z axis? is it 0mm or 2mm?
Posted: Sat Apr 09, 2016 12:42 am
by mini
2mm
Posted: Sun Apr 10, 2016 10:24 am
by Fluxcore
In repetier I beleave that in order to 0 the axis you have to home each one useing the little house buttons .
Posted: Mon Apr 11, 2016 6:04 pm
by Mark
so that's the problem, you need to manually move down the nozzle to the bed, and it should be 0 when just touching the bed. So you need to unscrew the bolt on your carriage for about 2mm and test it again.
Posted: Tue Apr 12, 2016 1:46 am
by mini
I will certainly try homing again ,although I think it's correct . But need to do other things first has it has taken over all other things and getting fed up with it . Will get back in a few days once I spend some more time on it . Thanks meanwhile for you interest
Posted: Sat Apr 16, 2016 12:00 am
by mini
Well another 4 hrs spent trying to get it to print on the Bed still pulling my hair out . Repeated homing process but still prints above the bed , altered g code in editor on slicer which had an effect of printing on bed ( actually too low ) then it reversed up to approx 200 mm and printed in air .
Did notice that when on slicer ,the model shows on bed then press print and then shows it up in air .
Please any suggestions again
Regards Brian
