Page 1 of 5
Heatbed not working G-2S
Posted: Wed Jun 15, 2016 6:14 am
by den3000
Hello! assembled printer Mini G2 Pro (single extruder)
The extruder is heated to a set temperature. The motherboard connector under the power of the extruder is switched
red diode.
If you turn on the hot bed, nothing happens. Indications temperature sensor does not grow. No indication diode.
The temperature sensor shows the room temperature
Help solve this problem. Thank you!
Re: Heatbed not working G-2S
Posted: Wed Jun 15, 2016 10:18 am
den3000 wrote:Hello! assembled printer Mini G2 Pro (single extruder)
red diode.
Hi,my friend
Have a look at this,it'll be helpful:
http://www.geeetech.com/forum/viewtopic ... 19&t=17039
Posted: Mon Jun 20, 2016 5:33 am
by den3000
Hi! the connector fuse of the heated pads were not soldered at two points. I soldered and earned printer Thanks!
Posted: Mon Jul 04, 2016 7:15 pm
by alberthandsome
I bought Folger prusa i3 Rev B and have a problem with it.
My Heat bed will not heat up and the heat bed thermister reads Zero C which is impossible (should at least be room temp).
The resistence of the Heatbed is 1.8 Ohms and that of the thermister is 95K (both within working range).
Also, The voltage at the Ramps Blue socket where the wires to the Heat bed are connected read 0 volts.
R Programming Training
DataStage Training
SQL Training
It seemed as thought that either the Ramps board is damaged or that the Repetier host software is either faulty or not configured properly.
SAS Training
Android Training
I installed a new Ramps board but have the exact same symptoms.
SharePoint Training
Any advice would be a great help
Posted: Tue Jul 05, 2016 2:48 pm
alberthandsome wrote:I bought Folger prusa i3 Rev B and have a problem with it.
DataStage Training
SQL Training
SAS Training
Android Training
SharePoint Training
I guess there has a open circuit on your heatbed thermistor.Have a double check on it.And refer the following info:
Posted: Thu May 07, 2020 8:46 pm
by datascienceinstitute
Check for the following errors
Fuse Damage
Electronics Damaged
Wrong Wiring
Testing Heatbed
Heat Bed Resistance
Data Science Training in Hyderabad |
Data Science Course in Hyderabad
Posted: Wed Jun 24, 2020 10:13 pm
by datasciencepune
Posted: Fri Jun 26, 2020 12:11 am
by DataAnalyticspune
I feel very grateful that I read this. It is very helpful and very informative and I really learned a lot from it.
Data Analytics Course in Pune |
Data Analytics Training in Pune
Posted: Fri Jun 26, 2020 1:11 am
by Businessanalyticspune
I am impressed by the information that you have on this blog. It shows how well you understand this subject.
Business Analytics Course in Pune |
Business Analytics Training in Pune
Posted: Thu Jul 02, 2020 3:58 pm
by datascienceprograms
I finally found great post here Very interesting to read this article and very pleased to find this site. Great work!
Data Science Training in Pune
Data Science Course in Pune
