Impossible to communicate with GT2560
Posted: Wed Nov 16, 2016 4:28 pm
by RugbyGoth
I just finished my Prusa i3 ProB but the X motor direction is wrong.
So I installed arduino 1.0.1 from the geeetech link and downloaded the marlin for proB from the geeetech link.
I changed the value of INVERT_X_DIR to true, compilation went smooth but uploading is stuck as you can see in the video:
https://www.youtube.com/watch?v=UYRRpoIj08k
I tried other connection cable, other ports but it's always the same.
As per my understanding their can be 2 issues. First it's a driver problem, I'll need to download the right driver and update it under windows control panel, but when I try to install the driver given by the geeetech link (
http://www.geeetech.com/wiki/index.php/ ... l_Software) It doesn't want to, saying an updated driver already exists.
The second possible problem is that the bootloader is failed, so I would need to flash it... it's here I could need help. I have a UNO board available to do so but does someone can help me in doing so???
Thanks!
Re: Impossible to communicate with GT2560
Posted: Wed Nov 16, 2016 5:42 pm
Have you checked if the board was detected by computer in Device Manager?
And did you select the right COM port?Maybe you can attach some pictures about it.
Posted: Wed Nov 16, 2016 6:05 pm
by RugbyGoth
Board is present on com20 in device manager
Posted: Wed Nov 16, 2016 6:08 pm
Strange thing...The board,the COM port,and the firmware are right...
The Arduino IDE didn't give any error msg when you compiled and uploaded it?
Posted: Wed Nov 16, 2016 6:17 pm
by RugbyGoth
No just uploading... For ever
I would add that repetier host can connect to the board but cannot send any command.
I will try with the driver given here
http://www.geeetech.com/wiki/index.php/ ... he_drivers
If it doesn't solve the issue I'll unplug the SD and LCD and finally everything.
It seems there is some electrical issue as when the TX/RX led blinks the screen becomes blank before showing two lines of row and then back to normal. I also have a sound like a motor trying to move. It seems like the board goes to reset each time I try to upload the code...
Perhaps an issue with the LCD/SD. I'll try to trouble shoot this tonight and come back to you. Thanks for your support william.
Posted: Thu Nov 17, 2016 1:36 am
by RugbyGoth
So... Driver change didn't do anthing
disconnecting LCD, SD and others : Nothing
I tried to burn the bootloader following those steps with a arduino UNO (
http://www.geeetech.com/forum/viewtopic ... 20&p=27978) nd it failed, now my board seems to be stuck with a wrong bootloader (used the arduino 1.0.1, will try with newest arduiino software..)
Edit : Bootloader change with 1.6.12 went well according to arduino console. But when I plug in the GT2560 it seems to go round and round inside the bootloader (2 blink... 2 blink... 2 blink...) when I try to upload marlin, same thing as before!
I beleive this board is faulty, can you send me another???
EDIT : I let the uploading do for more than 20 minutes and obtained this :
Code: Select all
Taille binaire du croquis : 115 760 octets (d'un max de 258 048 octets)
avrdude: stk500v2_ReceiveMessage(): timeout
avrdude: stk500v2_getsync(): timeout communicating with programmer
avrdude: stk500v2_command(): failed miserably to execute command 0x10
avrdude: initialization failed, rc=-1
Double check connections and try again, or use -F to override
this check.
avrdude: stk500v2_command(): failed miserably to execute command 0x11
avrdude: stk500v2_disable(): failed to leave programming mode
Posted: Thu Nov 17, 2016 4:54 am
by RugbyGoth
SOLVED!!!!!!
Issue was my laptop USB ports! They all were too weak I guess. Tried with my main computer and it worked flawlessly! ><'
Thank you!
Posted: Thu Nov 17, 2016 11:21 am
Congratulations
