Power Supply Problem - Geeetech I3
Posted: Thu Dec 15, 2016 4:41 pm
I set up the printer by following the steps in the manual and the indicated videos, but a problem has occurred and now it is not working. Before turning on I checked the correct voltage and changed the internal switch of the power supply as indicated (For 220V - Switzerland).
The printer worked the first few times I turned it on but the third or fourth time, it made a small noise in the power supply and after the internal light of the power supply blinked a few times, it went off. And now it doesn't turn it on anymore, just the power button that lights up.
I think the power supply came with some flaw.
I could not verify if the other components are working properly because of this failure.
I would like to know how to proceed (if it is possible to fix), if not I expect to receive another power supply.
