LCD2004 shows only 2 rows of blocks
Posted: Fri Jan 13, 2017 12:47 am
by mirox3mbg
I recently purchased your i3 pro B kit from your geeetech-official eBay store.
After I assembled it, the printer works, but the LCD2004 shows only 2 rows of blocks as seen in the picture I made:
https://goo.gl/photos/5SuCk6gBFTXT1zEv6
SD card works. Dial button also works - beeps when pressed and was able to home the printer by random rotation and press. Reset button also works.
...And yes, I made sure only discount smart controller is defined in configuration.h. And yes, I reflashed the firmware several times since it was not for my printer and all motors were reversed.
Re: LCD2004 shows only 2 rows of blocks
Posted: Fri Jan 13, 2017 6:13 pm
by bang
You mean you have wrong firmware?
You can try the right firmware to take a look:
download/file.php?id=2819
Posted: Fri Jan 13, 2017 7:20 pm
by mirox3mbg
No, I had the wrong firmware on my GT2560 board that came with my kit.
I have installed the right firmware after that, which is from this post:
viewtopic.php?f=10&t=17046 and the same as the one you listed.
Posted: Tue Jan 17, 2017 1:01 am
by crapzinsky
I have EXACTLY the same problem! But i have RAMBo 1.2g mobo that i bought recently.
Same here, but my display reset button doesnt do anything...
I´ve tried so many diffrent FW settings that im going crazy!!
I dont want to have the printer beside my computer all day, annoying bzzzz bzziii bzziuu bz bz
Posted: Tue Jan 17, 2017 5:18 pm
by bang
So the issue still there after uploading the right firmware?
Did you try swapping LCD and SD cable?
If so,you'd better check if your reset button was pushed down all the time incorrectly.
Then you can try unplugging all the cables on the board except LCD cable and power cable to see if there is a difference.
Posted: Tue Jan 17, 2017 5:32 pm
by mirox3mbg
How on earth do you think
mirox3mbg wrote:SD card works. Dial button also works - beeps when pressed and was able to home the printer by random rotation and press. Reset button also works
if I have swapped the LCD and SD cable?!
Same for the second proposal for "you'd better check if your reset button was pushed down all the time incorrectly".
Instead of proposing "smart" nonsens, just tell the other "smart" guy that manages your official eBay account to send me a new display or refund me the price for it.
Posted: Tue Jan 17, 2017 7:27 pm
by crapzinsky
mirox, a usual answer from them, they really think everyone is a
retard, of course we try everything before we post questions here. but ok i will try disconnect everything except lcd and sd but i dont have high hopes.
my screen worked fine on a sanginoloilu mobo...
Posted: Mon Feb 13, 2017 10:03 pm
by mirox3mbg
Geeetech sent a new LCD with cable and again does not work
Even the SD card does work only when board powered only by USB cable. It seems issue is with GT2560 board...
Left them a negative feedback on eBay so that other customers consider before buying this rubbish kits.
